Baseline Resources - reports
Good afternoon all,
I've been asked if I can generate a report from P6 to show our current plan resource amount vs our baseline resource amount.
i.e. when we baselined a job we had for example 20 tons of steel used, as the project has progressed this has changed a few times and I want to be able to get out of the P6 baseline what our original figure was so we can see how far it has changed in the time between.
I'm fairly sure that without detaching the baseline and going into it manually the above report can be done.  My line manager is convinced P6 allows this.
Can someone give us a defintive answer?  if I'm wrong then great can you tell me how to do this, if I'm right and it needs detaching then someone else has some work to do :)
thanks
Thom
T
Thomas Nicholson 👤 Member for 19 years 8 months
David,
I figured it's the activity usage sheet, but I still don't have an option to look at material on it, only labour and nonlabour. Also no option at all for baseline views.
Another clue please?
thom
David Kelly 👤 Member for 21 years 7 months
Thomas,
Its not a resource spreadsheet, but an Activity spreadsheet..... is that the clue you need?
T
Zoltan,
All our resources are set up as resource type 'material'. that's why i couldn't understand why it greyed out.
Thom
T
David,
Can i ask how you have got the baseline data on that sheet?  I cannot find a section for baseline data in resources anywhere at all.
Thanks.
Thomas,
I have a chart in my P6 which shows steel in units cumulatively from the baseline and the current schedule.
You cannot show this data in the top half of a P6 activity layout, but there are several ways to show this in a bottom layout. I have NO IDEA how you paste pictures into this STUPID dialogue... I will have one more try.... got it.
Couple of points.
Of course they don't want you to put costs into P6, have you any idea how many spreadsheet jockeys that puts out of a job? P6 is a better cost planning tool than it is a planning tool. it is a MUCH BETTER cost planning tool than Excel.
Anything you build in the bottom layout can be pivoted into Excel without pasting. This will keep all of the above spreadsheet jockeys properly employed, multyplying each cell by the cost of a ton of steel.
[[wysiwyg_imageupload:4458:]]
e one more try, may
Z
Zoltan Palffy 👤 Member for 16 years 10 months
if you did not set up your material resource a s a material type then it wil be greyed out.
T
Vladamir,
Normally I'd agree with you but unfortunately the company I work with don't allocate costs to items within P6 they prefer to seperate cost & programme (i know alarm bells all over) so I can't even use any of the cost information to see details either.
It really does look like you can't do it in P6, which is rather annoying.
Thom
V
David, you wrote:
"This is reason #3 in David's list of why materials should be entered into P6 as "Expenses" not "Material Resources""
But materials have costs and prodject budget shall include material costs. Is it possible to assign costs to Expenses?
It is necessary to get reports on both material amounts and costs. I doubt that this is possible if to enter materials as expenses.
T
Zoltan,
As always, thank you for the information.  However when I select Units the materials option becomes greyed out.  Is this the way the resource coding has been set up?  If I use the resource version I can see how many units I'm currently planning but not how many we planned for in the baseline.  As we don't store costs in P6 it's about the volume of material used.
Thom
Z
you can still get the infformaton as I described if it is a material resource.
The standard activity layouts let you pick columns under the "units" heading for Labour and non-labour resource from the Project and Primary Baseline.
However, you mentioned steel. If you coded this as a "Material Resource" - you are out of luck.  If you had coded the material cost as "Expenses" then you have access to Project and Primary baseline expense cost under the "Cost" heading in the column picker.
Z
view show on bottom activity resource usage
on the right hand silde click Activity Usage Profile options
now under data select units
now under filter for bars/curves select material
now under show bars/curves select Baseline and either Budgeted, Actual  or Remianing or ALL of them
you can also add a culumative cirve is you want by checking Cumulative
Then select Apply
