Using P6 to forecast equipment fuel consumption
Has anyone ever used P6 to forecast fuel consumption, based off equipment resources, or as a resource in and of itself? Is this a possible application, or would this most likely have to be itegrated with some sort of spreadsheet export to combine the data?
Ryan R.
Raymund de Laza 👤 Member for 16 years 6 months
As long as the fuel consumption is measured in unit/time and as well as equipment engine running is measured in time similar to activity duration. Then forecast consumption can be derived accordingly.
It is a possible application if you have the right scheduling software that can model Consumable Resources.
  • should be able to model consumption,
  • should be able to model deliveries,
  • should be able to resource level consumable resources, if consumable resources are depleted the activities are delayed until replenished,
  • common scenario on remote areas but not so common on most jobs unless site storing facilities are limited.
Maybe there is a way for P6 to mimic consumption/deliveries but doubt P6 will resource level the consumable.  In such case at every update you will have to manually resource level the material.
https://tensix.com/2014/05/when-resource-leveling-in-primavera-p6-wont-…
