Getting a login of NOTPRMUSER for certain projects. After reading an article it says this is a hidden generic Oracle account that is used if data is updated directly to the P6 Database in most cases instead of through a P6 module. Has anyone seen this before and had an explanation as to why this happened?
Our database person checked and there is no one who should have direct update access to the database. Version is P6 R8.1
Thank you.
here is my take on it
this is used to recored an action by the user where the "update_user" or "create_user" column is generated when p6 ties to recored Last Modified By (or Added By) column in the Activities View.
When an update is made from any P6 module (Project Management, P6 Web Access, API, SDK, etc.) the Last Modified By (update_user) or Added By (create_user) fields are populated with the name of the user that is logged into P6 making the particular update. So even using SDK could cause this.
This can also be seen if
P6 Job Services created/updated this particular record
The "Automatically fix errors" option was used when running Check Project Integrity
The project has been scheduled in P6 Web Access which is a bug
someone could have ran tthe tool to Check Project Integrity
