I have 3 projects which I have planned out, and assigned roles to the activities. What I am trying to get the P6 8.4 client to show me is a graph or just numbers of how many of each role we need for each month of the year. I have tried 'Activity Resource & Role Assignments' report and its halfway there, apart from if I need 3 of the same role at the same time it just repeats that information 3 times i.e.
Role Start Finish
Role 1 09-02-2015 - 28-03-15
Where as I am trying to get it to display the quantity required
Role 1 09-02-2015 - 28-03-15 x 3
Can anyone advise?
if you are looking at it on a monthly basis 172 is the standard manhours to be worked on a monhtly basis
or
8 hours per day
40 hours per week
or 172 hours per rmonh
and 2000 manhours per year (this takes into consideration 2 weeks vacation per year)
Hi Zoltan thanks for reply.
I followed the instructions and its nearly there.
If I highlight all the roles (rolled up), it gives the the graph, but is there a way to get the graph to distinguish the roles?
Also by calculating the average by 172 the vertical units are 0.3, 0.6, 0.9, can you explain what the 172 does please?
[[wysiwyg_imageupload:2367:]]
how about view show on bottom resource usage profile
on the left use the upside down triangle to gropu and sort by Primary Role
Roll up the role so that it summarizes the roles
then on the right just right click time scale change to Year/Month
then on the right just right click Resource usage profile options
on the graph tab check calculate average make sure that it says 172
this should give you what you need
