logic of the programme
Andrew Flowerdew 👤 Member for 21 years 5 months
It’s the same with any language (English is the language of this forum)- the more you use it, the better you become.
It’s good to see people trying to post in a language which is not their first language - please don’t stop posting just because you haven’t quite perfected the use of English. We’ll try and interpret what you write as best we can.
As I’m English I can say we are the laziest nation when it comes to learning a different language (most don’t!) and so those people that learn a different language should be applauded and encouraged.
As for the post, there is no right answer. Whichever method you use, be aware of what each means, how it works and then after rescheduling inspect the programme to make sure it still makes sense.
Easier said than done I hear someone say - I’ve got 3,000 activities or more! Try filtering on a time slice, the ones you need to check first are usually close to the data date. Then filter on float (say less than 2 weeks) and check them.
Like most things, no quick fix to getting it right.
Anoon Iimos 👤 Member for 19 years 8 months
It’s understandable that communications plays a vital part if not the most important aspect in this business. I have to admit that English is not my mother language (i just hope you understand me)and I’m not sure if I’m really good at it (only the listener or reader can determine that).
However, since this is an international community (I supposed), I hope there’ll be a spirit of sharing not only in technical terms but also the proper use of the applied language (which is English) ...forgive me I’m getting serious this time...I’ll be out of job soon...(maybe because of my English)..so please anyone...???
Ashraf Jahangeer 👤 Member for 19 years 1 month
Hi Ashraf,
Just to share the lighter moment..I am posting SOME MORE ENGLISH.....from India.
· Infosys, Bangalore: An employee applied for leave as follows:
"Since I have to go to my village to sell my land along with my wife, please sanction me one-week leave."
· This is from Oracle Bangalore: >From an employee who was performing the "mundan" ceremony of his 10 year old son:
"as I want to shave my son’s head, please leave me for two days.."
· Another gem from CDAC. Leave-letter from an employee who was performing his daughter’s wedding:
"as I am marrying my daughter, please grant a week’s leave.."
· From H.A.L. Administration Dept:
"As my mother-in-law has expired and I am only one responsible for it, please grant me 10 days leave."
· Another employee applied for half day leave as follows:
"Since I’ve to go to the cremation ground at 10 o-clock and I may not return, please grant me half day casual leave"
· An incident of a leave letter:
"I am suffering from fever, please declare one-day holiday."
· A leave letter to the headmaster:
"As I am studying in this school I am suffering from headache. I request you to leave me today"
· Another leave letter written to the headmaster:
"As my headache is paining, please grant me leave for the day."
· Covering note:
"I am enclosed herewith..."
· Another one:
"Dear Sir: with reference to the above, please refer to my below..."
· Actual letter written for application of leave:
"My wife is suffering from sickness and as I am her only husband at home I may be granted leave".
· Letter writing:-
"I am well here and hope you are also in the same well."
· A candidate’s job application:
"This has reference to your advertisement calling for a ’ Typist and an Accountant - Male or Female’... As I am both(!! )for the past several years and I can handle both with good experience, I am applying for the post.
ashraf alawady 👤 Member for 19 years 9 months
Dear all,
I’m discussing with you , checking any information available in the books related to the subject ,discussing the same with other proffesional persons home are working in the same field and finally i’m up dating you with all the new information may i can sellect in order to widdening the information circule and to spread the opinions and exceperiances.
A D 👤 Member for 19 years
hi Ashraf,
You have started the thread and then there was little bit confusion by others and then you resolved by putting clear-cut statements.
Anyhow, thats a good suggestion. Same logic we can use for Pipeline network project also.
Thanks buddy.
In roads and infrastructure projects , we are prefering to use progress overide logic based on the fact that this types of projects are horizontal projects and it can work out of sequance (if there is obestruction in on area or activities you can work in anther area or activities without gettig nigative impact on the completion date).
In Buildings project we have to use retained logic because you can not go out of sequance.
thanks
Very thorny question, although I do agree with the sentiments of the article refered to. Neither method may be ideal.
One way to minimise the effect of using progress overide is to use FF links with an appropriate lag although this too will produce unrealistic gaps in activities - it does though have the advantage of making the planner think about the relative relationship between the ends of activities and not just the beginning. (as if often the case)
It also curtails meaningless float in a programme and gives a much more meaningful critical path - if I’d been given a £1 for every activity I’ve seen which showed endless activities with float going on to the end of the project when it was so obviously wrong, I’d be retired now.
C
Charleston-Joseph Orbe 👤 Member for 20 years 10 months
Hello,
Just sharing idea.
The drawback in retained logic happened when it is very hard to check if the logic is really right for 5,000 +++ to 30,000 activities in the baseline programme that as per contract must be submitted within 28 days after signing of the contract.
In other words, it is a huge exercise to check if the logic is right.
IN monthly update, you will notice that the finish dates show too much delays.
ON the other side of progress update:
Progress overide gaves an option to rectify what was not right in the first place. Using change control mechanism, the planning team will have an option to re-sequence the updated activities to reflect what the future intent taking into consideration the information that will impact on the schedule.
Joseph
Hi Ashraf,
This is an interesting topic being discussed lots of time everywhere inclusing the link provided by Karim.
The brief is as follows.
Progress override deletes the predecessor link once an activity starts out of sequence and is hardly ever used.
Retaining logic makes the project duration longer and hence un-necessary delays are shown.
Having said that all planners while monitoring complex EPC/Shutdown scehedules with large number of activities still use Retaining logic for scheduling and then analyse the critical and near critical paths and modify/remove the logic based on positon in the field.
Ashraf Jahangir
