Microsoft Project
Description
Questions & answers for MS Project software
Container
No
Visualisation of resource availability
G
G T 👤 Member for 15 years 4 months
Dear Forum,
 I want to build a layout where I have:
 for example two persons - person A and person B who are available on rotational basis(when Person A is in country, person B is out of country) and their availability to be shown otimeline.jpgn a timeline...and once one person's schedule is altered i can enter his new availability somwhere in MS project and it will be reflected visually on the layout.
G
Dear Forum,
problem with percent complete
K
kp rao 👤 Member for 14 years 10 months
Dear all,
I am using Ms project 2007.Physical percent complete progress  bar not showing correctly.And also I want to show progress line based on physical percent complete.is it possible.When I try this progress line showing based on % complete not Physical percent complete.
And also I have problem while using duration per compelte.suppose the site team reports 90% and i update this the finish date changes to some other date.But I want to control finish date and keep 90%.is it possible.
kp
EV Cost and Schedule Indicators
Rohit K 👤 Member for 18 years 1 month
I have developed a schedule that is resource loaded with cost entered for the standard rates per hour for the respective resource. It is baseline,tracked and updated to date. In the calculation tab along with the task information for EV calculation % Complete is selected.
Now when I view the EV and EV Cost and Schedule Indicators (table - more tables), the BCWS and BCWP are indicating a value of 0, so are the various fields like SV, SV%,SPI,CV,CV%,CPI are also resulting in the value of 0.
Any suggestions to rectify this problem.
Rohit
Resource pool- WILL NOT SAVE!!! LOSES ALL LINKS??
C
charli r 👤 Member for 14 years 9 months
Hi guys
Master Project = PROJECT # 1, HOLIDAY, and OFF SITE VISITS
Individually, all of the resources have been set up to share resources in a file named 'resource pool'
when you view resource usage and all the files are open.... the resources are linked.
the Master project also reflects the resource sharing UNTIL you close the files!!! I save each file individually, then close the master. When I go to close resource pool, It doesnt matter if i press SAVE, SAVE AS or DONT SAVE AT ALL.... the links are somehow lost when it closes....
Copy time scale to excel by vba.
Hi every one.
I have a problem. I wanna to copy some data from time scale on resource usage view to excel worksheet.
I do it in table section of this view, but in timescale section it doesn't work. It seems "editcopy" & "editpaste" have some problem with this section (timescale section).
Do you know which code help me to copy selected timescale range and paste it in excel worksheet?
Thanks a lot.
