Asta Powerproject
Description
Discussion on aspects of Asta Powerproject
Container
No
Issues with Total Float in Report
Ran a report to an excel file and ended up with really erroneous float on some activities.  for example, one activity indicates total float of 331d when the true total float in only 111d Start (August 17, 2017) late start (December 6, 2017) and Finish (September 16, 2017) and Late finish (December 18, 2017).
The erroneous float appears to be assinged to all activities on a (7) day clendars and just on the report as the correct float is indicated on the barchart view on the screen.
any suggestions would helpful
Dan
Is there a way to link one file to another file?
Y
Yasine Ali 👤 Member for 10 years 9 months
Hi everyone,
Was wondering if it is possible to link one programme to a seperate programme (two seperate files)
For example if I have a Pre-Construction programme on one file and I would like to link it to a seperate file which contains the Construction programme.
How would I go about doing this? or is this not possible?
Prospective Forensic Analysis/Programme Audit/ Delay Analysis
I am dealing with  complex project that seems to be growing arms and legs and as such there has been slippages and delays to the programme.
Can anyone give me advice on how best to analyse this? I would like to carry out some detailed analysis and to carry out some root cause analysis but not sure where to begin.
Thanks!
Fonts and Formatting
Greetings Planners, my first post so be gentle.
I have inherited a programme and I am unable to increase the fonts in each subheading that's been created. I have successfully managed to change all the other fonts in the activities and other headings but these are stuck at 5. This makes them to small to read when I print the programme off. I have tried using the fonts on the 'Home' tab to no avail, likewise using the 'Default Table Fonts' in the Format tab. Both of which weren't of any use.
Any advice is appreciated.
Dom
How do you change duration default to days?
Hello
I use Powerproject 12 and when I enter the duration for a task and hit enter it defaults to seconds. Is there a way to make the duration column default to days unless another unit is entered?
I've tried formating cells, catogory duration and the time unit day with out result.
