There are three key approaches to capacity Planning:
1. Critical Path-based
Find out how many and when resources are needed for critical and near-critical paths and implement a solution to supply them when they are needed.
2. Resources Critical Path-based
Accept the fact that required resources not always will be available when they are needed and implement a solution to manage projects with limited constantly changing resources. Re-generate Resources Critical Path when supply or demand profiles are changed.
3. Agile based
Create a stable team of project resources and deliver based on their capacity.
Capacity planning helps ensure that the right resources are available for the right job at the right time and cost. However, it is easier said than done. Problems such as skills mismatch, lack of coordination between sales and delivery teams, frequent hiring/firing cycles, etc. obstruct the process.
I strongly recommend this insightful blog on the most common capacity planning bottlenecks and the best practices to manage them.
14 years 2 monthsThere are three key
3. Agile based
Each approach has advantages and disadvantages.
5 years 8 monthsCapacity planning helps
https://www.saviom.com/blog/effective-ways-to-manage-capacity-planning-…
