Check your columns then click on the column head. You'll see an arrow down/up indicating that that particular column is being sorted. Usually the colomns on the WBS node is according to number incremental.
I should probably clarify. It's my projects that won't show up in the same order when I shuffle them in the WBS view. I'm assuming the best way is to use a numbering system in the Project ID to get them in the correct order.
I tried to F5 with no success. Thanks for the reply Rizwan
13 years 2 months
Member for13 years2 months
Submitted by rizwan_wardha on Sat, 2013-05-18 12:45
16 years 3 monthsthats impossible
thats impossible
6 years 3 monthsHi Josh! Hope you have found
Hi Josh!
Hope you have found solution of the issue, please share it. I am facing the same issue.
16 years 3 monthspress F5
press F5
8 years 7 monthsHello Everyone, Please my
Hello Everyone, Please my schedule Start and finish milestones are not showing in my activities ...please how can i fix it
13 years 1 monthCheck View -> Group and sort
Check View -> Group and sort by:
Uncheck "Sort bands alphabetically" if checked. This might help.
Haakon
12 years 6 monthsHi Josh Check your columns
Hi Josh
Hope this helps
12 years 5 monthsI should probably clarify.
13 years 2 monthsDid u refresh the data its
Did u refresh the data its under file option. please let me know if its work or not
