ASSIGN RESOURCE BY ONE CLICK
16 years 4 months
Hai
Plz Send me ur mail id to my PP Message i will send u.
Anbin
15 years 3 months
cant’find the file....
If possible u can provide me the file...
16 years 4 months
Hai
Try to See RA folder in P3 CD.Inside the Folder u can see Following Excel File
1.Activity
2.Project
3.Spread
4.Custom
Using The Activity.xls File u can import data directly to P3
Anbin
15 years 3 months
hye anbin,
i’m sorry.I dnt understand what your meanings.
Please
16 years 4 months
Hai VeX
U Can use RA Appliction to Import Directly from Excel
Its available along your CD
Anbin
22 years 6 months
Looks like all these years of experience could not help you. But here is the solution
Select the activities you want the resources in and go to insert, resources and choose the resource you want and enter, and voila - There you are
15 years 3 months
thanks...that will become complicated when assign the budgeted since there is no way to direct import from excel..
24 years
Vex,
You can use global change, but first of all you need to define your resources on the resource table and then go to global change to assign the resource to activities. You may need to set up a condition to filter selected activities only. for example, you want to assign steel fixer to all concrete works, then you need to specify this in your condition. After assigning the resource then you need to go through each activity and enter the budgeted quantity. There is no such thing as one click though, you need to go through a process.
Hope this helps,
22 years 9 months
Hello Vex Zex,
it is not possible to assign resources to several activities at the same time
look at Global Change #2 to see how it is possible to replace existing resources on several activities at the same time
Alexandre
