Updated prgram as baseline program
16 years 11 months
Hi vinod
You can treat the updated schedule as target.Make sure the existing pro-gramme[Which you use for monitoring ] and target should not have same file name.Make sure your target and existing pro-gramme are in one folder
19 years
Hi Vinod,
Open the project that you wanted to save as target.
Select Tools->Project Utilities->Copy. Once copied, Select Tools->Project Utilities->Target, select the project copied.
Note: Only 2 projects can be display at the same time. If already have 2, replace any one of them.
