Total Manpower in Activity Column area
16 years 11 months
Please check it up
select data from menu option and choose custom data items and under activity option type it as RESO ,type character and choose length of it and description same for BQ1 type precision
then goto global change set the condition to select the particular resource you required
If RES EQ LABOUR
Then RESO EQ RES
this would display resource name, you could select from column option under name RESO
thn set the following condition for BQ1 to display quantities
If RES EQ LABOUR
Then BQ1 EQ BQ
16 years 4 months
Thanks for the Reply Shahul,
Exactly the same .I need them in the Column area to be displayed.(only the manpower).Also not using tabular reporting option.
Anbin
