You can add 2 or 3 custom data items as RUS1 and RUS2. Every item will give you 20 characters to add. If you want to show in reports you can show in layout view or in other reports. It will be easy for you just to import the descriptions.
EX:
RUSS1-FLOOR RUSS2-BLOCK RUSS3-WORKTYPE (depends on your WBS)
The problem is we have to present our schedules in both languages in Russian and English. I use log for russian part but log is also not enough for russian translation. that is the problem.
If you can divide the description in parts in a logical way, then you can add a activity code for the un-fit parts of the description and then you can show on the bar chart view as the columns next to activity description. Or you can add Logs to the activities.
17 years 5 monthsRE: long activity description
Sen sagol. Basarilar.
16 years 7 monthsRE: long activity description
Tesekkur Safak Kardesim. Ellerine saglik
Dear Faik,
EX:
Safak
Dear Safak
Dear Faik,
Safak
thank you Alex. It is strange.
22 years 8 monthsRE: long activity description
In P3 .... quick answer is No you cannot
In P6 .... put your description in the notebook
HTH
ALex
