Global change
22 years 7 months
Glad to be of help.
22 years 9 months
Joao,
it works, it works!
Muchas gracias, hombre
22 years 7 months
Yes, I think the answer is:
then RES EQ(AD) XYZ
and RDRV EQ "*"
Using it to turn all selected resources into driving. Or, perhaps, using two steps:
- First, changing the resources
- Second ,converting then to driving.
It is also advisable to use "Trial Run" first, just in case...
Good luck
Bonne chance.
22 years 9 months
Joao,
Thanks for answering my post
Maybe I was not clear enough
Is it posisble to change the "Driving resource" check box in the Activity Details Resource window by using the "Then" section in Global Change
e.g.
If ACT EQ 1234
then RDRV EQ YES
and RES EQ XYZ
Thanks for your help,
Gracias por ayudar me
22 years 7 months
Use " " or "*" for non resource driving, resource driving with EQ or NE.
HTH
