Primavera Project Planner - P3 Member for 18 years 6 months Member for 18 years 6 months Submitted by Jamie Welch on Tue, 2008-02-05 02:54 Permalink RE: Target Histogram Thanks guys- done and working, must have been a glitsch somewhere as I made a new copy of the project and it worked. Member for 18 years 5 months Member for 18 years 5 months Submitted by A D on Tue, 2008-02-05 01:38 Permalink RE: Target Histogram Hi Jamie, Go to Tools --> Graphic report --> Resource & Cost Go to CONTENT tab and tick the TARGET1 box U must have set target before doing this. Select the resource / cost item, whatvere u want and say RUN. It shud work for u Cheers, Ravi Member for 21 years 1 month Member for 21 years 1 month Submitted by John Lawson on Wed, 2008-01-30 17:26 Permalink RE: Target Histogram Hi Jamie, Try exporting the data out of P3 via an Excel spreadsheet format, first for Target then for the current plan. Then combine your data and produce your Target / Current chart on a user friendly graph. Regards John L. Member for 19 years 1 month Member for 19 years 1 month Submitted by Anoon Iimos on Wed, 2008-01-30 05:56 Permalink RE: Target Histogram no problem, if you want more, do not hesitate to hire me Member for 18 years 6 months Member for 18 years 6 months Submitted by Jamie Welch on Wed, 2008-01-30 05:47 Permalink RE: Target Histogram Thanks Anoon all done as you suggested and no luck.... Member for 19 years 1 month Member for 19 years 1 month Submitted by Anoon Iimos on Wed, 2008-01-30 05:36 Permalink RE: Target Histogram make sure your Target Plan is resource loaded; update it that it has progressed perfectly as planned; and make your histogram Log in or register to post comments
18 years 6 monthsRE: Target Histogram
18 years 5 monthsRE: Target Histogram
Hi Jamie,
It shud work for u
Ravi
21 years 1 monthRE: Target Histogram
Hi Jamie,
John L.
19 years 1 monthRE: Target Histogram
