Yes agree with Johny, Probably there is need of reviewing the logics. You might have set the finish date on Feb 08 but your network would result 09.find what caused them.
cheers.
18 years 1 month
Member for18 years1 month
Submitted by Johny Kesserwany on Wed, 2008-01-09 14:29
P3 is displaying the calculated Early Finish of the project if you select to display dates in the footer. May be your finish milestone is set to Feb 08 but the Project is ending in 09 ! as per your network..
You have to make a filter displaying all activities having early dates GT your expected finish date and find out why these activities are delayed up to 2009!
Good luck
JK
18 years 1 month
Submitted by Johny Kesserwany on Wed, 2008-01-09 14:28
Good luck
JK
19 years 1 month
Member for19 years2 months
Submitted by Tolulope Areo on Wed, 2008-01-09 08:31
you might be having floats after early finish date of July. You need to eliminate the float first. To have this, Try having mandatory constriant at finish date.
keep communicating.
17 years 10 months
Member for17 years10 months
Submitted by Mohammad Hamed… on Wed, 2008-01-09 06:56
I think this is the output of the project you’ve planned and if it is in contrast with the one you’ve targeted, you have to review the durations & types of the relations (links) of the activities defined and reschedule your project.
18 years 1 monthRE: EARLY FINISH
cheers.
Good luck
JK
Good luck
JK
19 years 1 monthRE: EARLY FINISH
Hello Nar,
I have tried to it, it did not work.
it is still reflecting a longer early finish date.
tolu
keep communicating.
17 years 10 monthsRE: EARLY FINISH
Hi tolu,
Hamed
