thanks ferdinand and oliver , that were excellent ideas.
now while in my wbs layout (with all activities filter) there are 1527 activties , where as when i sort by project i get 1531 activities , i dotn know where the 4 activities go in wbs layout.
regards
deb
18 years 3 months
Member for18 years3 months
Submitted by Ferdinand U. on Tue, 2007-08-21 11:40
In your WBS view, use a spare Activity Code field as a column, and fill this with a value.
Switch to activity view, and with the same column diplayed. Any activity which does not have an entry in the Activity Code field doesnt match the WBS ( I Think !)
18 years 9 monthsRE: changed the WBS :locate activities with old WBS values
regards
deb
18 years 3 monthsRE: changed the WBS :locate activities with old WBS values
mistake...should be --- you must NOT be in WBS layout when you filter
Gchange if WBST eq " " then WBS eq DELETE
then filter all activities WBS eq (no value)
take note: you must be in WBS organized layout when you filter...
23 yearsRE: changed the WBS :locate activities with old WBS values
