join projects
22 years 1 month
If you create a Group Programme and copy all your individual programmes into the group you will then be able to use the file 3007_200252492644_ProjectMod.xls or 3007_200252492644_Project.xls to modify all your codes, resources, wbs etc. These files are available as a download file on the Primavera Website. If you use the Primavera Knowlegebase search tool it is quite easy to find and even easier to use.
Graham
21 years 1 month
Yes
You use a P 3 Excell Documents
CD:RaSamplesExcell You need to download these from the P3 CD.
You then use the file Project.
22 years 6 months
I can live with duplication because I can make sure there are no duplicates before I import, but my question is, is it possible to export Code values and Code Value "DESCRIPTIONS" in the first place.
I have come across PRMBATCH which says I have to create a batch input file before I do the batch processing. How do I create a batch input file from an existing project?
22 years 4 months
mkt’s option to import data to Excel and then export from Excel to form a Master schedule is not workable 100% . Duplication may be get in such procedure. So we should opt/follow that path through which such duplication may be avoided.
Have any idea to overcome the above situation !!!
22 years 6 months
Thanks.
Can you tell me what "RA" stands for?
When I checked the export dialog box, I found no field for Code descriptions. i can only export and import code values and that too if they are assigned to activities only.
Is there any other way to export code values & descriptions and import them back?
23 years 8 months
Use RA can do it.
Export the dictionaries from P3 to Excel or Access or etc, then import it to the Master. Remember to check any duplication before import.
