What I understand is that in Tools > Tabular or graphical reports, all reports are based on either cost or quantity.
Assume that my schedule is not cost or resource (Qty) loaded. I can not use any tabluar or graphical report!! My schedule contains only activities and I want to develop Early and Late S curves for the planned % comp.
My progress measurment will only be based on Tools > Options > Summarization > Duration.
May be I was unable to explain my querry properly.
21 years 2 months
Member for21 years2 months
Submitted by Jaco Stadler on Sat, 2004-12-18 03:56
Well, as long as I am able to get the data (could be a column inside the P3 schedule) I can export it to Xcel. My objective is to get % late comp for each activity that can be summarized to an overall % comp. . . .
21 years 2 months
Submitted by Jaco Stadler on Sat, 2004-12-18 03:28
21 years 2 monthsRE: Planned % comp based on Late dates.
Daya I agree with you. Thanx Eric for you tip!! It really worked . .
22 years 7 monthsRE: Planned % comp based on Late dates.
Follow Eriks advice; it would be easier to introduce a dummy resource to accomplish your task.
22 years 6 monthsRE: Planned % comp based on Late dates.
Hi Muhammad,
The only way to do this would be to create a duration resource.
The easiest way would be to add a resource called time and set the budget quantity equal to the original duration.
You would then be able to do an s-curve.
Erik
The Easy Way is to export the summary the report I found the easiast is Tools / Tabluar Report / Tabular / RT1.
You modify this report (Or copy) Then you Export You Can Select Which Dates you want to export on this (Timescale)
Hope this help
Do you want to show the percentage in a Column on the schedule or on the S-Curve
