Primavera Baseline used bu Acumen Fuse
20 years 11 months
Use the Assign Baseline command and select the respective file to be assigned as the Baseline:
[[wysiwyg_imageupload:5484:]]
You will see the Symbol B after the Name of your Project in Acumen.
[[wysiwyg_imageupload:5485:]]
Andrew
11 years 10 months
seems P15.2 doesnt export the baseline in the XER file hence a default postion of the Acumen
11 years 10 months
16 years 3 months
I would assume that you have to tell Acumen what schedule the basline is. Depending on the version of p6 the baseline even though attached DOES NOT come along with p6 export.
My guess is that Acumen wil be using the Late start and late finish dates as baseline dates if a baseline is not provided or identified.
