If I have to allocate a gang of 75 carpenters for the entire project, should I enter 7500% in the max units column in the resource sheet and later as per the quantum of work in the task and duration I enter the required carpenters for them?
Is this correct?
Rohit
19 years 11 months
Member for19 years11 months
Submitted by Trevor Rabey on Wed, 2009-11-25 21:37
14 years 10 monthsTrevor, After you resource
Trevor,
After you resource load, How do you populate the manhour graph by either "tasks" or "roles". Please advise?
21 years 1 monthYes, Rohit
Yes, Rohit
17 years 6 monthsHi If I have to allocate a
Is this correct?
Rohit
19 years 11 monthsRE: Loading resources in Microsoft Project
There are several ways, some of which are not recommended.
This one is good:
Go to the Resource Sheet View and create and define them first.
Then go to the Gantt Chart View, select a task and use the assign resources icon/button on the toolbar to show the Assign Resources dialog... etc.
