Making it into a buffer task will only affect the start of the buffer task depending on the movement of its predeccesor, the back end of the buffer task will have a deadline constraint applied to it. What if i want the completion of a seperate task to drive the completion of a the buffer task (with a FF link)?
So i will have two task with a gap between them. The tasks may fluctuate in terms of start/completion dates, but a seperate task linked in between them will automatically fluctuate in duration along with them, to replace the gap between the two task.
24 years 4 monthsThe Hammock type activity
The Hammock type activity will work if task 1 and 3 are both milestones. Add them to a hammock activity called Guard delivered building material
19 years 10 monthsHi BenA buffer task is
Hi Ben
A buffer task is infinitely flexible between the movement of the start and finish links depending on both upstream and downstream movement.
What more do you want?
Mike T.
9 years 2 monthsHi Mike, Making it into a
Hi Mike,
19 years 10 monthsHi BenUse a BUFFER task.Creat
Hi Ben
Use a BUFFER task.
Creat a normal task using FS links and then Make Into> Buffer.
This is unique to Asta and does precisely what you wish.
There is an option to make it critical or not.
9 years 5 monthsHi Ben,I would have thought
Hi Ben,
I would have thought Asta has "Level of Effort" type tasks......?
