Formula Issues
Dipo Ismail 👤 Member for 11 years 6 months
Good afternoon,
I have just started using ASTA.
1. The  problem is I have put a formula in a column and whenever I open the programme it is comes up as incorrect, I have to then proceed to change a " back to ' to make the formula correct. I have to do this each time i open the programme.
2. Also how can i run a report using the column with the formula (after I have corrected it) as one of the fields. When I have tried to run the report it does not run, am i doing something wrong.
Many thanks for you help.
Dipo
