Find a video clip about the activity, and timing them for (maybe) 30 cycles at least. Then use software such as StatFit to analyze the raw data in order to obtain distribution with its parameter(s).
If you can get the recorded time for the activities of interest, i am willing to help you determine distribution.
Good Luck :)
20 years 5 months
Member for20 years5 months
Submitted by Peter Holroyd on Wed, 2007-10-17 04:15
Dont get to hung up on the minute detail. The fact you are doing a schedule duration risk assessment is good.
I usually use triangle (95/115)for D & E, rectangular (100/120) for materials & equipment and revert to triangular for construction (95/135) -this is biased to pessimism against "normal" values cause thats reality
Dont forget you are only modelling duration variances - use other values. The duration is a function of so many variables.
Try the next step and add in the risks to the analysis!!
18 years 9 monthsRE: Distribution Models in Pertmaster
Good Luck :)
20 years 5 monthsRE: Distribution Models in Pertmaster
