Lump Sum Contract Reductions
19 years 10 months
Then the previous answers from Tom and Zoltan are correct.
Don't forget to add for the extra design costs and setting out.
7 years
Dear Mike,
The Conditions of Contract is the FIDIC CONDITIONS OF CONTRACT FOR DESIGN-BUILD AND TURNKEY, FIRST EDITION 1995 Version.
Solomon
18 years 11 months
Solomon,
You are describing a contract dispute without even describing the contract form, particular conditions, or governing law.  On the face of it, I'm surprised the Engineer was able to unilaterally impose a deductive variation of this magnitude.
Under FIDIC contracts, the Contractor does have some specific rights, but he is not guarantied that the price will never be reduced by variation.  So demanding 100% payment for ~75% of the originally-contracted work doesn't seem exactly "fair."  I suspect that the general conditions under FIDIC don't address such a drastic reduction since the balance of variations on 99++% of projects are additive.  On large international projects where I've worked, we made sure our (non-FIDIC) EPC terms included caps on scope variation (generally 10% either way by cost).  Going above that would require opening up the contract for (renegotiation and) Amendment - which served the needs of both parties.  If a detailed review of the contract conditions doesn't reveal a solution in your case, then it sounds like an early case for the Dispute Board.
good luck, tom
16 years 3 months
same answer the contractor did not bid it by linerar foot.
7 years
Dear Zoltan Palffy,
Thank you for your comment.
The situation was like as follows. The road as per the original contract was planned to connect point A to point C through an intermediate control point B (i.e., A-B-C). However, immediatly after the Contract was signed, the Client changed his mind due to resettlement plans and ommitted the intermediiate control point B and changed it to another point, say point D but still the road will remain the same and connects point A to point C. But, such change has reduced the originally envisaged length by about one-fourth of the total length.
In view of the above the Contract Administrator then considered it as Variation of the contract and accordingly revised the lump sum amount pro rata with the length reduction which the Contractor has disagreed to accept.
The aforesaid was what exctly happened.
Solomon
16 years 3 months
you cant do that you did not bid on the road by linear footage.
for example you have a to build a bridge and the road goes over the bridge. So you deduct the road using the linear foot method what about the price of the bridge ?
You still need to be reasonable and come up with a fair way to give back a credit for the road work. Look on this site for standard pricing for road work by the foot or mile and use that.
Or if you were bidding a road job that was by linear foot what would the price be per liner foot instead of lump sum ?
