Qty / Manhour
16 years 7 months
Why would you use the client's estimate of manhours instead of your own?
15 years 11 months
Hi Mike,
If I make manhour as per the quantity I end up supplying a lot of workers.
Cause the client estimated Manhour for every quantity is over allocate?
Do you have construction activities man-hours?
Regard
Ron
19 years 10 months
Hi RonRon
You can make a direct extract of manhours from quantities using a simple percentage of Hours per Unit of measure.
It doesn't matter how accurate it is just so long as you use the same ratio for each report.
My motto is "Give then what they want" but not necessarily how they want it.
