The best first steps would be to gather your requirements as "Project Management" is a wide term.
If you want to take a look at our solutions, I would recommend to discover OnePMO (http://www.onepmo.com) that is natively multi-project oriented. You can manage, schedule both projects and resources and keep track of their progress while being able to compare planned Vs. achieved.
Please let me know if you would like to know more - you can reach me by email (isabelle.lepez at onepmo dot com)
If you're looking for a web-based solution, you may want to consider Easy Projects. Our collaboration features like video chat and file sharing are especially helpful if some of your team members are off-site or working from home. You can sign up for either a free trial or a webinar. Or both. :)
A good project management software that we use in our company is called Basecamp, try to avail their trial offer so you can see if the feature works for you. Now for order management software, I recomment WRNTY www.wrnty.com, this is what our company use for over a year now and we are very pleased with its features. It also has a trial offer that you can avail for free.
20 years 7 months
Member for20 years7 months
Submitted by Stephen Devaux on Wed, 2012-08-15 15:42
Does Invantive Vision compute critical path drag? If not, it's a pretty big omission. As far as I know, only Spider Project and the Sumatra.com add-on to Microsoft Project calculate it.
I would recommend Invantive Vision. Invantive Vision is not open source but is easy to use. U can easily add professionals to your projects and manage the task, hours registration and more. The software is web based and can be used with Microsoft Outlook. In this tutorial you can see how project management with Invantive Vision works.
The software is not open-source but it is scalable. Different versions for different user needs.
The software provides a free reader so anyone with access to the files can read the files though not edit them.
Same as most enterprise application you can set up user rights to control who have access and who can edit what.
There is no need to back up a monstrous database but individual files that might change while others might not. Each user can setup his own portfolios and define the users right so you need not to have a full time administrator as user will take care of their individual portfolios.
Each user can setup for Spider to auto-backup their jobs providing redundancy. This will allow individual users to recover lost files without intervention of DIVA administrators. This process is lightning fast, on the background and invisible to the user. So easy even the default is for auto-backup.
It takes about 2 minutes to install on each computer, no brain needed just an available finger to make a couple of mouse clicks.
The main brain behind the software development is available at this site. Just explore Spider Project forum.
Different to other enterprise software the individual project files can be stored on different folders. The following illustration shows how project files belonging to the same portfolio can be stored on different folders.
You can download a free demo from their website and make some test runs as to see how the files can be stored and saved within DIVA with no intervention of IT other than the control of DIVA user profiles.
The developer provides special pricing for academia.
You can use freeware http://www.ilovefreesoftware.com/15/featured/5-free-project-management-software-free-alternatives-to-microsoft-project.html for stand alone jobs and import them into Spider but be reminded that 100% compatibility between two software is a fallacy, in such cases the recommended practice is to import/export only once. MSP is somewhat limited so for some jobs exporting to a higher level software might be a must. Suggest using Spider for all your Portfolio Jobs while Open-project for the individual user that will administer their own small jobs independently from any portfolio. Do not expect freeware to be as good as full and original versions.
The decision is yours but do not use perception only, it can be deceiving, try it and ask others, especially to those in need of advanced functionality.
24 years 9 months
Member for24 years9 months
Submitted by Patrick Weaver on Sat, 2012-05-19 01:50
The software is not open-source, but is not so expensive ! it gives a much better ROI than many of the "global" solutions which do not offer such powerful yet flexible custom portfolio management functionalities.
Project Monitor has been adopted by some of my customers to manage large portfolios including strategic and ROI reviews.
15 years 11 months
Member for15 years11 months
Submitted by Raymund de Laza on Thu, 2012-05-10 07:53
I would recommend P6..... P6 is a very powerful PM software if it is used as intended and should be administered by a True Technically and Broad minded person.
I would recommend continue using ‘Microsoft Project’ else upgrade to Microsoft Project Professional 2010 which includes all the capabilities of Project Standard 2010 plus more features like at-a-glance resource management and team collaboration tools. Project 2010, built on SharePoint 2010, offers flexibility and choice and helps effectively manage any type of work, from simple tasks to complex projects and entire programs. It is a big jump in capability and gives project managers a lot of visibility into project conflicts, overbookings, and under-utilization.
16 years 11 monthsDear Brazil, The best first
Dear Brazil,
Isabelle,
13 years 2 monthsIf you're looking for a
13 years 2 monthsA good project management
20 years 7 monthsDoes Invantive Vision compute
http://www.dau.mil/pubscats/ATL%20Docs/Jan_Feb_2012/Devaux.pdf
Steve the Bajan
13 years 5 monthsI would recommend Invantive
Discover our site for more information
21 years 8 monthsI would recommend Spider
I would recommend Spider Project. The website http://www.spiderproject.ru/aboutus_e.php
24 years 9 monthsThere is a list of tools,
There is a list of tools, many open source at: http://www.mosaicprojects.com.au/Planning.html#Tools
13 years 5 monthsI would recommend Project
I would recommend Project Monitor. The website : http://www.viragegroup.com/en.html
15 years 11 monthsI would recommend P6..... P6
15 yearsMy company has been very
My company has been very happy with 4project system http://www.4projects.com/
13 years 6 monthsI would recommend continue
