This is a QS problem so I will have to go back 25 years.
Your query is not that clear - I assume that you are a sub-contractor working for a main contractor.
The measurement rules should be stated in the contract - if not then the published method of measurement that is applicable to your trade should apply.
Generally the billed rates apply to similar work executed in similar circumstances.
You will have to be more specific to get a more detailed answer.
PS You only need to press the SAVE button once - I have deleted the other two entries.
19 years 10 monthsHi Ian Welcome to Planning
Hi Ian
Welcome to Planning Planet
