The nature, extent and degree of project management can often be determined by the project’s "buildability"...in other words, how simple or complex is it to turn hundreds of pages of documentation, specifications and drawings into a definitive three dimensional structure...?
I never fail to appreciate the ability of humans to be able to convert hard-copy paper or electronic data or even the engineer’s and architect’s indeterminate concepts into some of the world’s most incredible buildings and structures!!
Sorry about the delay in replying; Ive noticed in a number of cases, that the way in which the project is managed depends not just on technical complexity but on political considerations as well, notably who the project sponsor is.
The complexity does, and does not, affect how the project is managed. As one reply says, if it is all in one discipline then thats a lot easier.
Complexity is a Systems Engineering issue. If the project is complex, how big is your WBS?, then you need tools from the Systems Engineering field.
However, these things run along a continuous spectrum and youll only notice the difference when you make large changes in complexity. Check out some work by Shenar and Dvir.
Case A: To build a single toilet . Place an MBA personnel to manage the work / project.
Case B: To build mega hightech buildings with hundreds CCTV/sensor/hiden camera fit-in toilets systems within. Place a PMP personnel to manage the work / project.
Case C: Place a business mgmt theorist in the toilet to figure out whats the toilet are for.
I would also say it depends on how much control and visibility the project Sponsor wants / needs. Some dont mind a very loosely managed project and some almost impose micro-management on the poor PM.
Additionally, a technically complex project may be technically complex but in a single discipline. So one, dedicated and skilled engineer could do it all, start to finish.
Once you introduce more disciplines, more designers, more contractors and different layers of customer (all with conflicting wants and needs), that is where management is necessary. It may not be technically complex, but the project environment is.
22 years 11 months
Member for22 years11 months
Submitted by Bernard Ertl on Sat, 2003-11-22 16:46
I would think that the importance/criticality of the project is the determining factor for deciding on how to manage it. The more important a project is, the more attention that managing it will receive.
14 years 10 monthsHai,Could anybody help me to
Hai,
Could anybody help me to understand the Delay Analysis and the Time Impact Analysis methodology with example.
thanks & expecting your advise,
Gliance
19 years 10 monthsTinaYou have broken the PP
Tina
You have broken the PP record by waking up a thread that is 10 years dead.
Apart from that welcome to Planning Planet.
Your topic is of interest but should be placed on its own pedestal.
Mike Testro (Moderator)
21 years 4 monthsRE: HELP - A Research Essay
Stuart
www.rosmartin.com
21 years 5 monthsRE: HELP - A Research Essay
Hmmmm,
Hope this helps.
Namaste
"...complexity of the work..." work eq. project ?
"..best managed.." manage the work = project.
Shall i put it this way:
peace
24 years 4 monthsRE: HELP - A Research Essay
22 years 11 monthsRE: HELP - A Research Essay
Bernard Ertl
InterPlan Systems Inc. - Project Management Software, Project Planning Software
