Activity Start Time
16 years 3 months
1st you need to turn your times on edit user prefernces Dates tab under time select 12 hour show minutes
2nd set the project start time to 8:00 am or the earliest starting times of of all of your calendars say 8:00 am
3rd then you need to set your data date time to 8:00 am or the earliest staring times of all of your calendars.
4th all start minestones should be set to  8:00 am or the earliest starting times of of all of your calendars
5th all finish milestones times should be set to 5:0 pm or the latest finishing times of all your calendars
6th the project must finish by date should be set to 5:0 pm or the latest finishing times of all your calendars
7th all actual start dates should be set to  8:00 am or the earliest starting of of all of your calendars
8th all actual finish date should be set to  5:00 pm or the latest finishing times of all of your calendars
9th edit user prefernces time units tab under durations format make sure that decimals are set to 2 places.
10th look at al of your originial durations and remaing durations and make sure that they are whole numbers
11th press F9 and change the data date time to 8:00 am or the earliest starting times of of all of your calendars
done
22 years 9 months
Virendra,
Open the appropriate calendar, click on Detailes work/hours per day,
click on specific 30mn periods to switch from off to on
by default, the working day spans from 8:00 am to 12:00 am and from 1:00 pm to 5:00 pm
11 years 1 month
Good Morning,
Can anyone help me to find out and explain me, how to change the start time i.e. 07.00AM and breaktime 1 hours in P6.
Thanks in advance
VKD +7 701035 4732 / +91 78694 65514
15 years 8 months
Thanks - though in this instance I have not imported or exported anything to Excel.
Any other solutions?
14 years 8 months
This will happen only when you are importing from Excel. In such case, please incorporate Calendar timing along with your dates.
