Database Error
12 years 8 months
Hello!
I have a P6 8.4, by 2 years no problems, until today.
Exception EconvertError in module PM.exe at 0000B846. TCVirtualTable.Refreshappend: UDFVALUE: 460.89 is not a valid floating point -> Data saved to C:\PRBADDATA.TXT
The log file is not on the Disk. The unique difference was the P6 re-installation with JAVA 8 (8.4 came with JAVA 7), it works fine and corrected another XML error (error to import by bad Java address), not imported the XML, but I could work with the other files and xer. Closed it and restarted, then this error appeared.
Any suggest will be welcomed!
Thanks, Nelson
Hi! I corrected my problem by rewriting the DB.
Nelson.
16 years 3 months
compress the database, compress the file and clean pobs tables file here is how
compress the data base
Click on start All Programs, Microsoft SQl Server 2005, SLQ Server Management Studio
Authentication: Should be SQL Server Authentication
Login: sa
Password: Prima123Vera
Then click connect
on the left Expand the database folder and click on pmdb$primavera
now right click on pmdb$primavera and select task
now select shrink
now select database
at the bottom select OK
when it is done
now select shrink
now select file
the select ok
colse Microsoft SQl Server 2005, SLQ Server Management Studio
Clean the POBS tables
Login: sa
Then click connect
Then up top select new query
Then type this
updatestatistics project with fullscan ,all
updatestatistics task with fullscan, all
execsp_updatestats
then right click and select execute
you can then celan the POBS tables
then type this
delete POBS;
the right click and select execute
now you can close and exit out of sql
NO either delete project that you no longer need
or select file sed project and email then to yourself
you can also create ANOTHER database
19 years
Kandarp,
To run Database Configuration: (by default)
Select Start-> Primavera-> Help & Utilities-> Database configurations
A Database Configuration Dialog box will pop-up then click Next. Tick "configure my database Connection" then click Next..Next...until reaching User Name and Password. Enter pubuser (for both user name & password) then click Next until the Dialog says "Connection Successful!" then click Finish and run Primavera again.
15 years 5 months
thanks for your reply Rodel,
sorry but I could not understand what do you mean by ’run database configuration’.
Are you saying to access or open database (MSSQL server)without going through primavera interface and delete those projects that are not required? If so, could you explain me how can I open /operate it.
I had never tried MSSQL so do not have much idea how it works.
Many thanks for your help.
Kandarp
19 years
Kandarp,
Try to run Database configuration and it may help.
