Open the XER file in a text editor like Notepad. Do a find and replace that swaps "AS_EPS" to become "AS_Global" and then all the EPS codes and assignments to activities will be imported into the destination database as a Global Activity Code.
Takes a few seconds to do and brings across all the data - as long as you're allowed to do such imports!
EPS Level Activity codes CAN be imported from another database, but needs a bit of work up front.
The only Requirement is that an EPS Activity Code Type with Exactly the same name must already exist in the structure above the Project being imported into.
In order to Import a list of EPS Code values, you would first need to check that the EPS Activity Code Name already exists in the Target Database prior to importing.
If this EPS Activity Code Type exists, then all the code values & assignments will import.
EPS level Activity codes ONLY import into a database if the database has EXACTLY the same EPS structure as the database the project(s) were exported from.
20 years 6 months
Member for20 years7 months
Submitted by Santosh Bhat on Wed, 2021-01-27 13:22
Only Activity codes that are assigned to the activities that are being exported will be in the XER file. If you have defined them in your Global Code Dictionary, but not used them yet, they will not get exported.
16 years 3 months
Member for16 years4 months
Submitted by Zoltan Palffy on Wed, 2021-01-27 13:11
during the import process when you get to the Update Project Options screen select
Modify at the bottom
on the Data Type:Project section
under Activity code value and activity codes
and Prject code assignments
in the action column change all 3 of these INSERT NEW
also the other machine must have the rights to import the codes
if you are taking about activity code values
make sure that you have the proper rights to do this
go to admin
security profiles
upper left global profiles
then click on the profile name that has the check mark ie.e Administrator
then under Privilege make sure that ALL of the boxes are checked
if you are talking about the activity code dictionary
The only other way to get the activity CODE DICTIONARY is to use a 32 bite machine with P6 and SDK on it and then export the Global dictionary to excel
Global Activity Codes are not getting exported in the xer file. I tried opening the exported xer files with Wordpad & also in another PC but the global activity codes are not present in both cases.
EPS activity codes are there even if you check your xer with any text application such as wordpad or import it back to your machine with same EPS structure. The reason it was not imported to other machine because EPS structure will not be the same as in your machine therefore it will be ignore. The correct way of exporting activity codes is either Project activity codes or global activity code.
(You can convert to global your current activity code before exporting to xer so other machine can read it.)
20 years 6 monthsOpen the XER file in a text
8 years 1 monthEPS Level Activity codes CAN
21 yearsEPS level Activity codes ONLY
20 years 6 monthsOnly Activity codes that are
16 years 3 monthsduring the import process
5 years 8 monthsGlobal Activity Codes are not
20 years 1 monthhi all, I've got the same
hi all,
I've got the same problem here.
I also tried using global activity codes, but they did not come along as I thought they would.
I cannot use project activity codes since I need these codes to be available for more than one project...
are you sure there isn't a way ?
I tried recreating the same EPS structure, and it worked fine on one machine and not on the other...
I'm lost !
19 yearsRE: importing an XER file with EPS activity codes
vito,
