Based on my experience to my windows xp laptop, shrinking decrease the usage capacity of my database and the performance is quite better than before. I am not sure if you should re-arrange first before shrink. But it works fine without doing that. But, make sure to backup your database.
Try to reduce the data from your database and just import again the moment you will need it. This is also what I am doing.
Arnold
17 years 8 months
Member for17 years8 months
Submitted by Sampath Lakshm… on Mon, 2009-05-18 06:39
Thank you very much Mr.Arnold. I have checked your first option which is correct. I am using windows xp. Can you tell me whether shrinking of data base will give effect in performance of primavera and should i use re arrage before shrinking...?
1. Try to check your Edit --> User Preferences --> Startup Filters, all mark must be under the "Current date project only".
2. If you are using windows vista try to change the setting from your Control Panel --> Power Option --> Preferred Plans, then select "High performance".
3. You can compress or Shrink your database using the "SQL Server Management Studio Express".
16 years 3 monthsdo thisGo to startAll
do this
Go to start
All programs
Select Microsoft SQL Server 2005
Then Microsoft SQL Server Management Studio
Server name is the name of your computer\PRIMAVERA
Authentication is SQL Server Authentication
Login: sa
Password is: Prima123Vera
Select Connect
On the left expand the databases and select pmdb$primavera
Uptop select New Query
on the right type this
update statistics project with fullscan ,all
update statistics task with fullscan, all
Then right click execute
Then type
exec sp_updatestats
15 years 8 monthsHi,You can try below
You can try below solution:
18 years 9 monthsRE: P6 Stand Alone Slow performance
Luca
Maybe youll first try backup and restore. "Corrupt" might be too many extensions of some tables which may lead to "out of memory".
22 years 4 monthsRE: P6 Stand Alone Slow performance
what I found out that if I import several schedules into the DB after a while it get corrupted and need to re-install a brand new DB
Generally with the DB corrupted my system performance was very bad
L
18 years 6 monthsRE: P6 Stand Alone Slow performance
You are welcome..
17 years 8 monthsRE: P6 Stand Alone Slow performance
Thank you once again Mr.Arnold.
Thanks alot for ur technical sugestion. I will try in that way and reply you. Any way so kind of u..
warm regards
Lakshmi Narayanan
Hi Sampath,
Arnold
Thank you once agin for ur help
warm regards
Lakshmi Narayanan
Hi Sampath,
Hope this helps.
Arnold
