A quick way of building a project plan from a list is using import and export function
Normally I copy the list of WBS from the orignal specification, BOQ, Deliverable list, milestone list ...
Fill that in a excel spreadsheet with preliminary dates and resource budget hrs Q $, then import it into my P3e schedule. Once its in then I start to detail each WBS and link them together to create a CPM.
HTH
Alex
22 years 3 months
Member for22 years3 months
Submitted by Kevin Button on Wed, 2007-07-04 20:57
Other than what is listed on Primavera help I have found only 2 other shortcuts/tips.
1. When you have selected a bar that has a + or - symbol, pressing CTRL + TAB will expand or collapse that line. This works on Resources, codes, activity summary lines and other hierarchical structures.
2. While in the Activities screen use CTRL + Roll Mousewheel to scroll one screen at a time.
16 years 3 monthswhat you mentioned are
what you mentioned are standard windows operating based short cut and will work in any windows based program and is not just MS Office based
F9= schedule project
F5= Refresh screen
F1=Help
F2=edit
F3=Find Next
F7 = Spell Check
F10=Save schedule or comit changes
Shift +F2 = Reorganize now
Shift + F9 = Level Resources
Ctrl-N = New project
Ctrl-O = Open Project
Ctrl-W = Close all projects
Ctrl-P = Print
Ctrl-X = cut
Ctrl-C= Copy
Ctrl-P = Paste
Ctrl-A = Select All
Ctrl-E = Fill down
Ctrl-F = Find
Ctrl-R = Replace
Ctrl-Num + = Expand all
Ctrl-Num - = Collapse all
6 years 2 monthsThank you for this.
Thank you for this.
20 years 7 monthsRE: Hotkeys/Tips/Tricks in Primavera
good approach Alex.
regards
22 years 8 monthsRE: Hotkeys/Tips/Tricks in Primavera
HTH
Alex
22 years 3 monthsRE: Hotkeys/Tips/Tricks in Primavera
18 years 5 monthsRE: Hotkeys/Tips/Tricks in Primavera
In P3 help, check the shortcut keys.
You will find a load of shortcut keys
