No impact at all as P3e/P5 assigned max 3 baseline at a time. Actually its four (4) if you include Project Baseline for EV calculation plus Primary, Secondary and Tertiary baseline. It’s just creating another record into PMDB Database same as creating a project.
Rodel
18 years 5 months
Member for18 years5 months
Submitted by Patricia Le Clainche on Fri, 2007-06-08 02:03
I was convinced we were limited to a maximum of 50 baselines for a project. So thanks for this info.
Nevertheless, if we are not limited in Baseline creation, could it have an impact on performance of P5 ; in this case, it would be better having a limit.
Regards.
Patricia
19 years
Member for19 years
Submitted by Rodel Marasigan on Thu, 2007-06-07 09:55
19 yearsRE: EPS Activity code values in P5
Patricia,
Rodel
18 years 5 monthsRE: EPS Activity code values in P5
Rodel,
Regards.
Patricia
James,
Yes there are limits depends on your setting on Admin Preferences. To set the limit select Admin-> Admin Preferences then select Data Limits tab.
EPS/WBS tree - 1 to 50
OBS tree - 1 to 25
Resources tree - 1 to 25
Role tree – 1 to 25
Cost Account tree – 1 to 25
Activity Code tree – 1 to 25
Resources Code tree – 1 to 25
Project Code tree – 1 to 25
Maximum Activity Code per project – 0 to 500
Maximum Baseline per project - no limit or up to valid integer value
You can also set the ID code length
Rodel
