You can install P5 locally into your laptop without the need of installing Oracle.
As Matt said u can run P5 using the MSQL server (which will be installed automatically), after that u can import/export or backup the database easily by going to: Start-->All Programs-->Microsoft SQL Server--> Enterprise Manager, then select your database and click on Import/Export or Backup/Restore.
Or u can simply export the schedules from the P5 itself using file--> export.
HTH.
Karim
19 years 7 months
Member for19 years7 months
Submitted by Karim Mounir on Mon, 2007-06-04 11:27
HTH.
Karim
19 years 7 months
Submitted by Karim Mounir on Mon, 2007-06-04 11:26
HTH.
Karim
19 years 7 months
Submitted by Karim Mounir on Mon, 2007-06-04 11:25
HTH.
Karim
19 years 7 months
Submitted by Karim Mounir on Mon, 2007-06-04 11:24
The local copy runs through a MSSQL server which is set up on my hard drive. I would give you more details but unfortunately our IT department locks us out from finding useful system info!
19 years 7 monthsRE: P3e Database on a Server and a Local Copy
Al MacLeod,
HTH.
Karim
Al MacLeod,
HTH.
Karim
Al MacLeod,
HTH.
Karim
Al MacLeod,
HTH.
Karim
Al MacLeod,
HTH.
Karim
18 years 7 monthsRE: P3e Database on a Server and a Local Copy
Hi All,
I run P5 locally as well as through server.
Hope this helps though.
