Thanks for the reply. Tried purging deletes as you recommended but this didnt really speed things up.
In the end I exported as MPX files which appears to have carried across all logic and resource information except calendars.
So after creating the calendars in the MSP global view was able to change the resource calendars and level. This got the dates within 24-48 hours which was ok.
22 years 10 months
Member for22 years10 months
Submitted by Ronald Winter on Fri, 2007-03-30 09:06
This is a classic symptom of failing to purge deletes before exporting. Try Admin / Purge Deletes before exporting next time. Also, once you interrupt a process like this, I find that MSDE gets ‘all tangled up’ and works much faster if you first re-boot. Good luck!
18 years 7 monthsRE: MPP Export from P5
Ronald,
22 years 10 monthsRE: MPP Export from P5
