2-if using v4.1 get latest SP (tehre is heaps of bugs with imports etc).
3-ask him to export his plans again from P3.
4-import it into the P3e.
if no error, kool!
if yes error, send it to your PAR and ask them to import the same file, if they dotn get an error, then re-install your P3e. or even send it to Izam or us on here.
22 years 8 monthsRE: Importing P3 files
If you receive a message in relate to userfil.p3 meaning your clients P3 file require fix before the importing.
So what you should suggest is to rebuilt the P3 file by using either batch or P3fix to fix the P3 file first
Once its fixed then you can import
Good Luck
Alex
20 yearsRE: Importing P3 files
U can also try p330xerconvert.exe that u can find on common files/primavera common/convert
Regards.
21 years 1 monthRE: Importing P3 files
hello,
try this first,
1-if using v5- get Service pack 2
if no error, kool!
Kind regards,
Vu Dang
www.dangcorp.com
19 years 5 monthsRE: Importing P3 files
Brother,
To import p3 from p5, is not the problem. But certain thing require to setting up the activities code or wbs....
but if u using p3e, its too difficult to import p3.Otherwise, please directly email me maz.aizam@simedarby.com for any confusion there.
