Much of it depends on your settings, however try the following. Create a calendar with 24hr working and make sure the little box work hours/ day has 24 in it.
Assign it to your activity. Your settings may show the duration in days & the admin preferences may be set to an 8 hour day, therefore as you enter 1d, you get 00:00 to 08:00. Unless your administrator can set your default hours per day to 24, you will have to enter the equivalent 8 hour days the show 31-Oct-06 00:00 to 01-Nov-06 00:00 (3d) or enter 24h directly.
Your user preferences can be changed if you want to show the hours worked.
19 years 3 months
Member for19 years3 months
Submitted by Tu Huynh Van on Tue, 2006-10-31 06:53
examp: activity 1 - duration: 1 day (08h), the Bar normaly will be show from 08:00am to 17:00 pm - this is OK, what the solution for this one if we want to show this bar for the whole day: from 00:00am to 24:00
Please advice,
Tu,
19 years 10 months
Member for19 years10 months
Submitted by Paul Garland on Tue, 2006-10-31 04:45
Im not entirely sure what you mean, however if you go to edit > user preferences > and select the Time Units tab, you can set the unit of time to a day rather than by the hour. Also set the decimal places to zero so it will not allow a fraction of a day?
19 years 10 monthsRE: Gantt Chart
19 years 3 monthsRE: Gantt Chart
Hi Paul,
Thanks for your infor,
but i mean that:
Please advice,
Tu,
That may do what I think youre looking for.
Hope that helps
Paul
22 years 8 monthsRE: Gantt Chart
Dont understand your question please give a bit more info
