Hans, if you are in the Netherlands is it safe for me to assume you are working for Shell? If this is the case then you have a Shell GI-D machine which will have a bunch of restrictions that will create problems when using this feature. As Arthur says check your restrictions. Use the following path "C:\APPS\", this directory has no restrictions on a Shell GI-D enabled machine and should work fine when using this feature of Primavera.
19 years 3 months
Member for19 years3 months
Submitted by Arthur Godbeer on Fri, 2006-08-25 11:55
19 years 4 monthsRE: Print layouts to HTML file
I had restricted acces. Thanks for all the replies. It is solved now.
By the way, I am not working for Shell.
19 years 6 monthsRE: Print layouts to HTML file
19 years 3 monthsRE: Print layouts to HTML file
Do you have unrestricted write access to the location and directory to where youre exporting? And enough disk space?
