First mister planner planner shoud IDentify himself and indeed you can easely change the ids by using a global change and build (afterwards) all sorts of intellegence in it. a template of this global change has already been made so look it up and change it for your best result.
regards
Henk
21 years 3 months
Member for21 years3 months
Submitted by Henk van der Heide on Tue, 2005-06-21 17:06
regards
Hek
22 years 4 months
Member for22 years5 months
Submitted by Mohammed Muneeruddin on Tue, 2005-06-21 07:39
1.YOU CREATE NEW ACTIVITY CODE - SAY - "NEWID" IN YOUR PROGRAM
2.YOU EXPORT YOUR PROGRAM TO EXCEL INCLUDING ACTITY ID AND ACTIVITY CODES -BY SORTING THE WAY YOU WANT IN MSP (TOOLS,EXPORT,....ANY REPORT,FORMAT,SORT).
3.OPEN THE NEW FILE IN EXCEL OR LOTUS- FILL UP W THE NEWID THE WAY YOU WANT AND IMPORT BACK TO P3.
20 years 11 months
Member for21 years
Submitted by Andrew Edwards on Tue, 2005-06-21 06:22
The only way Ive done it previously is to build the intelligence into the Activity ID from the start. I fear doing it retrospectively isw going to be a manual job.
If you do find a way, please let us know.
Andy
20 years 10 months
Member for20 years11 months
Submitted by Bill McMichael on Mon, 2005-06-20 21:21
I cannot think of a way to easily populate the activity ID or another field with a number corresponding to its group/sort order sequence other than manually typing in the number.
23 years 4 monthsRE: Changing Activity ID’s
thanx for all of u guys,
it worked with me as mohammed said.
it exports the activity codes in text custom fields.
21 years 3 monthsRE: Changing Activity ID’s
regards
Henk
regards
Hek
22 years 4 monthsRE: Changing Activity ID’s
... IN CONTINUATION TO MY EARLIER REPLY
4. PERFORM GLOBAL CHANGE BY INSTRUCTING CHANGE
ACT EQ NEWID
I HOPE THIS HELPS
BEST REGARDS.
MUNEER
HI
IF YOUR ARE USING P3 THEN I SUGGEST
20 years 11 monthsRE: Changing Activity ID’s
Andy
20 years 10 monthsRE: Changing Activity ID’s
Bill
