Copy Picture
16 years 9 months
[Silly (and not on the subject) post was deleted by the Moderator. This thread is now closed as the subject is obviously complete.]
16 years 9 months
[deleted by Moderator]
16 years 9 months
All right! That’s good then! Sorry! Cheers!
16 years 9 months
I- Forum Guest - Beh, did apologise to Paul, you-Forum Guest, read before you write.
16 years 9 months
Hi Forum Guest,
I’m surprised that you wrote: "Paul, I am rather surprised that you do not know this." You - Forum Guest - should know that in P3e/c there is no command like "Copy Picture" in P3 3.1, that one helps you to capture the screen, the Gantt Chart. The option with Notebook is someting else...Or you can create pdf files from your Gantt and then from within Acrobat say: Select Graphics...copy, paste...Paul’s right!
16 years 9 months
No, P3e does not include copy picture (camera icon) option built in directly like P3.
16 years 9 months
Sorry Paul,
Missed the topic.
Beh
16 years 9 months
As I said earlier,
1) go to Notebook, add a topic, say "P3 actitivity log info", click the "picture" icon to insert.
2) From the dialog box, go to browse to select the source of the picture and click enter.
3) Go to View, Bars, select current bar (or whichever that you are working on), click on the Bar Labels tab.
4) Select the position you want to show the picture, then, duoble click under Label to open the drop down menu. Select "Notebook P3 Activity Log Info"
You should then be able to view the picture.
I have inserted gif file, wow, it moves.....
If you are utilizing the html format as part of your reporting, you can save the layout and publish as html format (we are setting up this option for our present project - Ranaissance Residences), the graphic is still there, but this time it does not animate.
Good luck.
Beh
23 years 8 months
Press Alt-PrintScreen, capture the image, paste to your required location, is it help?
If you want part image only, paste the image in PaintBush, cut out the area you want and paste onto final location.
16 years 9 months
What I am looking for is the camera icon which allows you to copy part of the P3 - Table / Gnatt layout without using a third party screen capture programme
24 years 6 months
Not that I found, try a programme like SnagIt.
Paul E Harris
www.eh.com.au
16 years 9 months
go to notebook, there is an option for graphic insertion at the bottom.
Beh
