Oracle Primavera - PM6 Member for 21 years 6 months Member for 21 years 6 months Submitted by Taher Abdel-Aziz on Sun, 2004-07-25 16:05 Permalink RE: Is P3ec Supporting Hijri dates wa alikom alsalam I didnt fiend away yet but I am trying ,with one of my friends working in programing, to create a micro doing the job directly. taher Member for 16 years 9 months Member for 16 years 9 months Submitted by PPAdmin on Fri, 2004-07-23 09:22 Permalink RE: Is P3ec Supporting Hijri dates Assalamualaikum Taher Have you found a way to add holidays also? Zubaidi Member for 21 years 6 months Member for 21 years 6 months Submitted by Taher Abdel-Aziz on Sat, 2004-04-24 02:46 Permalink RE: Is P3ec Supporting Hijri dates Hi all I think I found the solution it is hard one but that is what I reach. It is as follow: 1- Add two define user column (Text) 2- Export the two early date’s column & the two users define to excel using P3e utility tulles & SDK. 3- Use excel format with Arabic environment to change the dates to Hijri dates. 4- Change the cell format to text. 5-Import the data again to P3e using the same tool. 6- Hide the early date’s columns and change the other columns title to early dates. Finally the client is satisfied by this solution. Thank you Member for 16 years 9 months Member for 16 years 9 months Submitted by PPAdmin on Fri, 2004-04-23 08:53 Permalink RE: Is P3ec Supporting Hijri dates Dont think that will work as requested in that it will still show Gregorian calendar dates. I think it is one you have to take up with Primavera. Member for 21 years 6 months Member for 21 years 6 months Submitted by Taher Abdel-Aziz on Thu, 2004-04-22 10:12 Permalink RE: Is P3ec Supporting Hijri dates Dear Sir, Thank you again. The Hijri dates is the moslems calender which months start date are calculating from moon live cycle. It is around 355 daysyear. As I said the problem is that the client who located in KSA want the Hijri dates to be the basic date. Thank you Member for 21 years 6 months Member for 21 years 6 months Submitted by Taher Abdel-Aziz on Thu, 2004-04-22 08:55 Permalink RE: Is P3ec Supporting Hijri dates Dear Sir Thank you for your reply. But the problem is that the client wants all dates (early, late & actual) in Hijri format not just calculating the scheduel with the proposel you suggest. Thank You Taher Log in or register to post comments
21 years 6 monthsRE: Is P3ec Supporting Hijri dates
wa alikom alsalam
taher
16 years 9 monthsRE: Is P3ec Supporting Hijri dates
Zubaidi
Hi all
Thank you
Dear Sir,
Thank you again.
Thank you
Dear Sir
Thank You
Taher
