then click Ok and RUN...all your activities you want to change will be change and if you want to change some activities in different zone, you have to filter it first.
19 years
Member for19 years
Submitted by Rodel Marasigan on Thu, 2010-07-22 02:53
Show Calendar ID column on Activity Window. Change the Calendar ID of the first row. Highlight all rows that require update or use filter then right click and select Fill cell.
15 years 3 monthsRE: TO ASSIGN CALENDAR ID BY ONE CLICK
Ok..thanks
16 years 5 monthsRE: TO ASSIGN CALENDAR ID BY ONE CLICK
Hi Vex,
Go to Tools --> Global Change --> Add --> Modify
in
Data Item: put CAL(stands for CALENDAR ID),
Criteria: EQ
Data Item/Value: choose your calendar
19 yearsRE: TO ASSIGN CALENDAR ID BY ONE CLICK
Vex,
