Primavera P3 - Batch Structure
19 years
Alexander,
P3 Batch is used for updating data in P3 database. Input file is a text file using Batch Structure and command. You can find the manual at P3 CD called P330batch.pdf
Instruction, File Structure and Command are describe in the manual. Data format is ASCII or text and every character count per character/column are clearly describe in the manual.
Batch command can be found at C:\P3WIN\P3PROGS\PRMBATCH.EXE by default
