Because the metrics is meaningless it does not matter how you update, anyway it will still be nonsense. You can use a single resource a single activity that span the whole job duration, assign a predefined curve and you will get equally invalid measure with less effort, if this is the idea. With P3 you will get a meaningless S-Curve with early and late dates at the click of the mouse, at this P3 is so good that even meaningless is easy.
If you stick to PP in a few months you will be throwing dirty water at me, and both will laugh, believe me here you will get good at planning, keep asking here.
15 years 5 months
Member for15 years6 months
Submitted by Yaser A. Al-Bustanji on Thu, 2010-05-20 17:50
16 years 11 monthsRE: how can i obtain s curve
Hi to all
In the tools ,option , graphical reports there will be choices early & late, select which ever you need
18 years 3 monthsRE: how can i obtain s curve
use tabular report tabular
or use graphic report with labels
15 years 5 monthsRE: how can i obtain s curve
how to set up S-curve in P3 obtaining Late Dates using tabular reports resouce loading?
21 years 8 monthsRE: how can i obtain s curve
Yaser,
thank you for answer but during updating what i do
you want scurve without resource or cost?
if you are in a hurry atleast add one resource for all activities and make BQ EQ OD
