I suffered a similar issue to the dates moving here are some of the things that resolved it.
dont forget to contrain the date!
if you are scheduling from a particular date and it is not constrained it will simply start the activity at the earliest possible time hence it moves it back to the data date
if it is being driven by another activity that finishes late this will push it out everytime you hit F9 so double check your predecessors.
I also found that if i was trying to replicate an MS project into P3, MSP allows activities to finish and start on the same day however if P3 is set to schedule in units of a day it will always start thefollowing activity the next day therefore pushing everything out.
Yeah youre right, its because thats the Projects finish date... I guess that wasnt a good example. I give up on this useless program... I can make a better schedule with Paint
19 years
Member for19 years
Submitted by Rodel Marasigan on Thu, 2010-05-06 20:21
I don’t think I have "level automatically".. you can take a look in the screen shot. I made a simplified example, except in this example it created extra lead time and before it was creating lag time. In the new sample I want the project to end on Aprl 16, but you can see P3 creates lag time out til June 10 and I don’t know why??
15 years 6 monthsRE: P3 keeps changing dates when I don’t want it to
Thanks for your help.. This program annoys me because its the first program Ive ever used that I couldnt just figure out how to use it on my own.
15 years 11 monthsRE: P3 keeps changing dates when I don’t want it to
Hi Mike,
Persevere hope it helps.
19 yearsRE: P3 keeps changing dates when I don’t want it to
Mike,
Can you check File-> Project Information if you have Project must finish date define? It seems always finishing somewhere in Jun.
New Sample
Does this forum have no option to upload photos?
Mike,
Can you check Tools-> Schedule or (F9)-> Option if level automatically is selected? It should be Off
Is it not possible to edit posts?
Pic 2 second try
24 years 6 monthsRE: P3 keeps changing dates when I don’t want it to
Pic2 does not work.
