P3 File Fixer is cool. I used it and the file size becomes smaller. And probable there are some corrupted files that was cleaned by the PFXW.exe.
But the ghost activities I mentioned still remains. So, What I did is, when the ghost activities showed up, I "cut" (Ctrl+X) it instead of delete it. After that, the ghost activities never showed up again.
22 years 10 months
Member for22 years10 months
Submitted by Ronald Winter on Mon, 2010-01-25 11:07
No, the behavior that you describe is not normal for P3. It sounds like a corrupt database. This can happen in P3 when multiple people access the same schedule at the same time (especially during power failures/computer crashes/etc.). It is time to drag out the old P3 File Fixer. On your computer, locate the following P3 program and run it,
C:\P3WIN\P3PROGS\PFXW.exe
Select the schedule in question, check all of the fix options at the bottom left of the screen, then Run. The Help button can educate you further. Good luck!
22 years 10 monthsRE: A Strange P3 Occurence.
After trying everything else, sometimes just using P3 to copy the schedule to a new schedule cleans-up problems that other efforts miss. Good luck!
19 years 1 monthRE: A Strange P3 Occurence.
