If you have Access 2007 you can open the Excel file from within Access and although you cannot use Save As to save in dbf format you can use External Data/Export/More/dbase.file for this purposes.
The add-in must be easier but the reference came out to be a demo version limited to 30 records, they promised a free update I am looking to get a hold on it.
17 years 1 month
Member for17 years1 month
Submitted by Santhosh kumar on Thu, 2010-01-14 01:09
Thank you very much Rafael. I will try to follow your advice. I am migrating from P3 to P6 but not all are using P6 until now. If I will create a schedule in P6 our client will not be able to open it so I need to do it in P3.
The big diffrence I notice between P3 and P6 is that the schedule in P3 is separate from the program itself. While in P6, the schedule is inside the program.
Once you delete or uninstall P6, all your schedule are gone while in P3, even though you uninstall it, your schedule is still there.
cheers
21 years 8 months
Member for21 years8 months
Submitted by Rafael Davila on Wed, 2010-01-13 14:47
Microsoft Office 2007 stopped supporting many file formats, including wks and dbf. So even if you have Access 2007 you won’t be able to save in dbf file format, if you still have Access 2003 you can.
Try OpenOffice 3.0.1 Calc. It’s part of a free open source Office suite that can read in Excel 2003 and save as DBF.
As a hint I recommed you set OpenOffice Options to save in MS Office format.
P.S. You got to accept it, P3 is obsolete. Try using P3 Primavera Mail with Outlook 2007, it won’t work unless you trick the software default. As new Office and Windows updates surfaces more and more functionality will be lost and many in your company might be at risk of not even being able to access it.
21 years 8 monthsRE: Import/Export in Excel 2007
17 years 1 monthRE: Import/Export in Excel 2007
Hi Florante,
Try this one.
http://thexlwiz.blogspot.com/
Santhosh
19 yearsRE: Import/Export in Excel 2007
cheers
is free!
http://download.openoffice.org/contribute.html?download=bouncer&product…
