U have to create the users that can access your project database (in NetSet) giving the necessary rights in P3.
Be sure that only you have the right "read/write". It will be required to change the right to user "everyone" from read/write to read only.
To all the users you want to prevent from having complete access give access "restricted". Then go into the restrictions button and define which things he/she will be allowed to do. There is a lot more options then Global changes.
This rights remain property of the database no matter where you store your project
20 years 5 monthsRE: Lock Global Change
HI,
16 years 11 monthsRE: Lock Global Change
In the network connected systems the client will have an access option he can enable the respective function to his members at any moment
16 years 4 monthsRE: Lock Global Change
Thanks for the reply,
If the access for many functions such as Global change,filters...etc are denied how to get access once again.
With Thanks & Regards,,
Anbin Ponnith
It is possible in a system connected in network ,where you could block them using access option i am not sure about stand alone system
